Discuss Ply and Self Level Compound? in the British & UK Tiling Forum area at TilersForums.com.
Tricks13
Hi, 1st post on the forum but have had much help reading everyone elses probs, am fairly new to tiling.
I have a 35 sqm kitchen/dining room floor to tile in 600x600 polished porcelain. Most of the substrate is concrete but some is a mix of chipboard and floorboards. What would be the simplist way of getting the correct level base? The existing concrete will need some SLC in areas should i use this over the whole floor or ply over the boards and chipboard and then self level to the height of the ply over the concrete? Thanks
DHTiling
Hello and welcome.........
You can self level over the concrete section no probs....I would overboard the timber section and level the concrete to it....you will need to put a movement joint where the concrete meets timber as they will expand at different rates and the timber section could have deflection also and cause the tiles to de-bond.....you can use Silicon the same colour as the grout to make this joint in the tiles.....
Reply to Ply and Self Level Compound? in the British & UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
