ply or plasterboard ?
jake72
Hi all first time posting here.
I am sure that it has been covered before,
Have been asked to install a bathroom over easter.
Existing walls around bath are lathe an plaster one one side and brick plastered wall on the other.
Plaster is blown on both walls, so i am going to remove all old tiles and plaster. On the brick side I am planning to use tanalised battens to level out the wall, then use either green plaster board or 12mm exterior ply.
I know that the ply will be more expensive, but feel that it will be stronger (plus its for a friend, dont want it to fail!)
Asking you proffesionals, what would you prefer to tile onto, green board or ply?
Or could I splash out on aquaboard for the area around the taps and shower head, then use green plasterboard for the other areas.
I am a chippy. but needs must at the moment,
And if ply, any thing to do before I Tile. ie pva the board, leave a gap between boards, Silicon gaps.
Any help gratefully received.
jake
hi mate
avoid using ply :thumbsdown:
use plasterboard / green board/ backerboard etc but avoid ply mate
ed
I would just use plasterboard and tank any area's subject to constant wetting or risk of water ingression.
Thanks for all the advice guys,
So thats final, no ply then!
I have just been down to Wickes (UK diy chain), and priced up aquaboard and mr plasterboard, Price is fine.
Or are you going to tell me to steer well clear of them ?
I wasnt going to buy adhesive or grout etc from them, but buy good quality stuff (bal?)
but without having a trade account for anywhere else the prices seem ok for board?
Once again thanks, and if this bathroom goes ok I will get the kitchen and fiited wardobes job as well ! will keep you posted.
Choice is fine.
You will get just as good adhesives etc cheaper than BAL..
Mapei/Ultra/PCI..etc also very good brands.
Why not dot and dab the plasterboard to the wall instead of batten? Its much faster than levellling in a batten then screwing the boards up. It also very wasy to do it you havent done it before.
jake72,
mikethetile,
jake72,
mikethetile,
