Porcelain Plywood + Flexible adhesive or Plywood + Ditra matting
Main thing ensure al floor boards are secured first ,then ply ,i did a job similar,the joinerpulled up the boards ,then 18 mm ply onto joists ,then ditra ,big area do it once properly ,
If you do as @3_fall you do not at any point get a continuous joint coming from the joists to the to surface
Only timber floor I have ever had a failure on was floorboards over layed with 6mm Hardie.
You end up with basically 3 joints in around 5 inches and that’s where the tiles cracked.
I always take them up now.
Thanks for the reply @Boggs . Yes I was told the substrate floor needs to be a decent thickness. 6mm defo too thin
Cheers for the reply. I now have two people on here, yourself and 3_fall who have recommended pulling up the floor boards. Looks like this is the way to go. Regards to the Ditra, any particular brand/type of adhesive you use for the Ditra to ply and then tile to Ditra?
I'd use 12 mm Hardiebacker board over top of your floorboards but ensure that the floorboard aren't loose or rocking then screw backer board every 150 mm or 6 inch in old money if you want to be over cautious screw 10 mm centres use yellow zinc screw though as they don't corrode apparently
Porcelain
Marty M,
Andy Rhodes,
Marty M,
Andy Rhodes,
