Rich
There are endless posts on this forum from people who have come across problems with tiling onto ply. Some have had pro tilers tile the floors in there homes and the tile installation has failed later down the line, others are doing there own tiling and have installed plywood onto a floor ready for tiling as they think that it is a good substrate to tile onto. This isnt the case, plywood really isnt a good substrate to tile onto at all.
Years ago plywood was used as a substrate for tiling because there was little else on the market. Builders would over board floor boards with plywood to give the tiler a flat and even surface to tile onto and in time this has become the norm to a lot of builders, even more DIYers and even some tilers. The problem is that you can tile straight onto plywood with no problems as long as the right ply is used and it is installed correctly, this rarely happens as nine times out of ten the ply that is used to over board a floor before tiling is left over from another job to save money. I have been on many jobs over the years where builders/plumbers/tilers have over boarded with ply as a solve-all because it is quick,easy and relatively cheap.
Some of the problems with tiling directly onto plywood are:
There are products on the market now that mean that there is rarely a need to tile straight onto plywood. Cement backer boards are a great way of over boarding floors. There are several different brands on the market and can give you the best possible substrate to tile onto if they are installed properly.
Some benefits to over boarding with a cement backer board rather than ply are:
If ply wood must be used, it must be installed correctly to minimize the chances of a failed tile installation.
Note: Not all cracked or loose tiles are due to a problem with a ply substrate, this is just a common problem that I come across a lot.
- Ply wood swells and contracts with moisture and humidity, as the plywood swells and contracts the bond between the adhesive and the plywood boards can be broken
- A lot of plywood on the market now a days is treated with chemicals to make the boards fire resistant, these chemicals make it very hard to bond to
- Plywood rots very easily when it comes into contact with water, most areas that are tiled are areas that are likely to become wet
- Plywood can absorb moisture out of the adhesive that is being used for tiling and begin to rot
- Cement backer boards are completely impervious to water, they do not swell or rot
- They offer a superb surface to bond to
- Floors can be over boarded with boards 6mm thick rather than 18mm with ply
- They can be installed to make the substrate waterproof, ideal for wet areas and wet rooms
- BS state that the ply used for over boarding floors must be a min of 15mm thick (I recommend 18mm min)
- The ply must be boil and water proof marine grade
- The ply must not be damp/wet or show any signs of rot or damp
- The underneath of the boards should be sealed to reduce the risk of the ply absorbing moisture from underneath
- BS state that the boards must be mechanically fixed down at a min of 300mm centers (I recommend 150mm to be safe and to use either ceramic coated screws as the screws can rust and discolor grout)
- The boards shouldn't be butted up together, a gap of around 2mm should be left around each board to allow for expansion
- The joints in the boards should be staggered
- Before the ply is put down, some people recommend that the ply is left in the room it is to be used in over night so that it will do any expansion/contraction before it is fixed down
- The tile adhesive manufacturers instructions should be followed to the letter and the correct adhesive must be used (I will only use a 2 part adhesive to tile onto ply)
- I would also recommend tanking any ply that is going to be tiled onto with a tanking kit like Mapei's Mapegum
- Small hair line cracks begin to appear in the grout joints between the grout and the edge of the tile
- These hair line cracks spread over time and sections of grout will start to come away leaving gaps between tiles
- One or two of the floor tiles will show small hair line cracks running from one edge to another
- these cracks will spread and get worse and the cracked tiles will become loose
