K
kaide
Hello,
Looking for some advice. Had our new kitchen fitted last October. The floor is half concrete and half wooden. The builders replaced the floor boards with 18 mm plywood and leveled the whole kitchen floor with self leveling compound. We also had electric under floor heating put in as there is no radiator in the kitchen.
The porcelain floor tiles move over the plywood area. Also, when you tap the tiles, a fair few of them sound hollow over the concrete area of the kitchen. The builders are coming back tomorrow to rip the floor up and replace the plywood with 22 mm and do the floor all over again.
Can any one shed any light as to why the tiles sound hollow on the concrete sectioned and movement on the plywood section please. The tile adhesive they used was called setaflex and is the correct adhesive.
The under floor heating was put on 3 weeks later after the floor had been laid. The builders gave me no instructions as how you are supposed to gradually increase the temperature. I had initiallty had the temp on high for the first 24 hours until they told me otherwise.
Any advice much appreciated.
