C cass May 30, 2010 #11 Re: porcalain on walls I take it the concreat screews dont go in to plugs and screew right in to wall
C cooperrmb May 30, 2010 #12 Re: porcalain on walls I think scottley if referring to tapcon fixings which you screw straight in concrete or brickwork you can get them from srewfix
S Scott May 30, 2010 #14 Re: porcalain on walls Thats right, pilot a hole and screw them in, i have only started to use these recently when fitting doors and windows and they are excellent. I must admit i havent used them on dry lining yet
E easyt May 30, 2010 #15 Re: porcalain on walls Would they be any good for fixing studding to existing walls.
S Scott May 30, 2010 #16 Re: porcalain on walls easyt said: Would they be any good for fixing studding to existing walls. Click to expand... Oh yes, perfect for that.
G Gazebo May 31, 2010 #18 You could stick and screw marmox board in the wet area to make it watertight and to allow for the heavy porcs.
