Porcelain tile chip repair...
I've purchased a repair kit off the tinternet....... So will let you all know in due course what it's like.. 🙂
Did it work? I've had some laid and the silly place-holders the builders used have left chips on corners! .....also, I have one I dropped a basalt stone on when massaging. Thanks 🙂
A method I have used in the past to repair chips with quite good success was to use grout and mitre glue.
I would find a grout as close to the tile colour as possible (can mix different shades) then using a Stanley blade put a tiny coat of mitre glue onto the chip. Next sprinkle the grout over the glue and push it in with the blade, put on more glue then grout until slightly proud, compacting it with the blade each time. Once done can use the activating spray to set it off. Then using either a brand new blade or fine grit sandpaper get the repair flush with the tile. Will stick like sh*t and should be water resistant. Hope this helps anyone 👍
Excellent tip. 👍👍
Andy Allen,
Kevbos,
Andy Allen,
Kevbos,
