Discuss Porcelthin Advice in the Canada Tile Advice area at TilersForums.com.
wayne
523
leeds
got a job coming up and the customer just told me he's getting 2.4x0.8 porcelthin tiles. He tried telling me it will be quicker to tile as there so big After a bit of advice as I've never fitted anything this big on walls or floor before. I'll be using slowset and serrating wall and tile. Would you recommend lash clips or not?
They won't be Porcelthin.
Largest size Ray does is 1800x900x5.4mm
But nevertheless, some form of levelling clip would often be used.
Quicker than what exactly? Haha
Just make sure your prep is the best u can get it, there's no packing out with thin porcelain.
You want perfectly flat substrates.
Rizzle from the Portizzle
hi wayne i would not recommend serrating the wall and the tile you will find the hydrolics of moving the tile with two layers of adhesive back breaking on a tile that size and you will not get a full bed and with the adhesive so thick as it drys out it could well pull the tile out of shape .on a tile that size you will need to prime the wall
to slow the adhesive down to give you more working time .the adhesive should be a wet mix to the max with water .next
serrate one way with the ribs top to bottom to break the ribs you want to move the tile left to right .next you need to
flat scim the back of the tile 1mm will do. this will stop the adhesive grabbing the tile and will help roll over the adhesive ribs so the tile floats into position .you are welcome to give me a call. or pop in for a little training
After doing a course at Ray's & attending the Coverlam course at Grespania I would still be a bit dubious about fitting tiles that size.
Ray, I would have thought using a 6mm on wall & tile would give for a far superior bond?
I know you would be looking at a carrier system to get the tile into position.
tested the two serrate method again and again and again if the surface is uneven it can have its bennefits but if the prep is right and you want it right with large format .then you cant beat a 10mm ragni serrate to the wall and a flat skim on the back of the tile it will cut the resistance by 70% resulting in a far better bond
L
LM
Ray I have a job next week with 1200x1200x10 porc on a large floor, would you say that I'd also be better with say a 12mm notch to the floor and a flat 1mm bed to the tile rather than notching the back of the tile as well?
Reply to Porcelthin Advice in the Canada Tile Advice area at TilersForums.com
L
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
gamer1
leeds
Website
http://www.waptiling.co.uk
Porcelthin Advice
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
