Discuss Porcelthin Advice in the Canada Tile Advice area at TilersForums.com.
What are you using to cut them & lift them?
I noticed in another thread you're quoting for a porcel job Stef,
d'u get it?
Praps your question was a bit more general than how I read it.
I use 4 different methods of cutting.
Depends on what I feel like on day and type of cut tbh.
I use Ray's speed cutter on repeat cuts typically.
Then it's a toss up between the 1280 sigma and my Montolit Flashline, which I do like a lot. That's a 3.6m slide cutter. And exceptional value for money!
That notwithstanding, if I was to choose again, I may go for Antonios Freecut instead. More expensive tho. (Quite a bit)
And there's the trusty grinder with the right blade. (Important decision to be made there I feel)
As far as handling goes, I've not actually tried a carrying system, but I believe they can be a hinderance rather than a help. But I feel sure I'll buy one one day! Haha single handed operating vacuum pumps I reckon will probably be the best solution.
The best tips I could give u on handling are, don't clump them on walls or doorframes when moving them, especially if they've had a checkout cut in them!
If you're gonna stand them on edge, make sure it's ALWAYS the longest edge!
If you're gonna stack a pile against a wall, make sure both the tops and bottoms of each tile are touching each other. (No voids between tiles)
So pretty much all common sense stuff, nothing u don't already do!
And if this isn't what u were asking, :D it don't matter cos it's made sitting in rush hour traffic on my way to work, far less painful! :p
Ps. Nearly all of this I've been lucky enough to pickup thro working alongside Gary & Ray!
Stef
d'u get it?
That's a perfect reply to my questions, cheers Marc.
Gary phoned me for the job then Ray gave me a buzz, I'm in the process of pricing up the job as its through Ray & he has put my name forward for it.
I was looking at buying a Kera Cut but not sure whether it's worth it yet & also looking at the Kera Lift but again not sure.
The job I'm looking at has a lot of cutting & although I've got one of Ray's speed cutters I feel that the Kera Cut would help the job if I get it.
Gary was telling me he was working with you on jobs, I wouldn't mind coming down for a couple of weeks to work along side Gary & Ray to get in about some porcel-thin.
Stef
naturally sigma 128. it's faster.
Got one Antonio, these tiles are 1800x900mm though..
The freecut system I feel is better because it is more slimline. Suckers within the runner! Others have suckers to the side which makes it very wide limiting it at times, well that my opinion anyway.
And if u are bored there's some staircases here u can come play on for a week! Haha
I
Italy
I'm ready marc :)
Reply to Porcelthin Advice in the Canada Tile Advice area at TilersForums.com
L
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
gamer1
leeds
Website
http://www.waptiling.co.uk
Porcelthin Advice
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
