Discuss Prep in the Australia Tiling Forum area at TilersForums.com.
Hey guys, just wondered how you would prep this. Floor to be tiled is chipboard, 50m2! Porcelain tile 600x400 layed brick bond. Multiple rooms, biggest being 20m2 .
I was thinking 6mm cement board bedded into flex adhesive and screwed. Stagger boards etc. Any thoughts? Products you would use instead? Ditra? Etc etc
Cheers
One Day
I did similar recently. pallet load of 6mm hardibacker onto chipboard (110sqm). Had to go under and brace the joists in a few areas but it was solid enough. I don't like HB as a rule, but as an overlay for tiling onto it's preferable to foam core boards in my opinion.
I used an impact driver with a decent wera bit holder and a few boxes of 25mm spax screws.
I toyed with the idea of an auto-feed driver for a few hundred quid but I don't do this so much.
macten
1,158
Nottingham
Like impish says there are quite a few adhesives that say they are capable to go straight onto chipboard but I would worry (even if the worry is unfounded) I like to stick to what I know works. You should be looking at about £500 for hardi, screws and addy (doesn't need to be flexi - just a cheap rapid set grey).
J Sid
I would have thought more like £850 plus fixing
macten
1,158
Nottingham
52 boards from CTD £7.99 + vat (they knocked me £1 off a board last time I bought in bulk - and they deliver to site for free), 25mm turbogold screws from screwfix - buy the huge packs for best savings, and enough cheap addy for 50m2 of your chosen notch size - I use 6mm if it's nice and flat. Last time I did one like this I got a mate in to give me a hand and we had all the full boards down by dinnertime.
Reply to Prep in the Australia Tiling Forum area at TilersForums.com
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Hi guys. Been out of the tiling game for some years and just about to tile kitchen and hall in...
goz
Chichester, West Sussex
Prep
Tags
prep
    Votes: 6 4.7%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.7%
    Votes: 16 12.4%
    Votes: 31 24.0%
    Votes: 3 2.3%
    Votes: 2 1.6%
    Votes: 19 14.7%
    Votes: 18 14.0%
    Votes: 15 11.6%
    Votes: 6 4.7%
    Votes: 3 2.3%
    Votes: 2 1.6%
