Discuss Preparation for shower tiling in the Tanking and Wetrooms area at TilersForums.com.
Ollywest
Hi all
I have a new build extension and the bathroom has been lined with green plasterboard then skimmed by the builder, looking for any advice on preparation for tiling a shower area? Seems it would have been better for it not to have been skimmed, can the plaster be tanked or primed, or overboarded with hardie-backer? Tiles will be 30 x 90cm ceramic.
Any advice welcome.
Waluigi
Remember- MR plasterboard shouldn’t really be skimmed unless prepped with thistle bond it.
If the tiles are too heavy the walls shouldn’t be tiled and instead taken down or overboarded with a suitable tile backer board.
Keep in mind the minimum/maximum compensation of any potential shower screen if overboarding.
Time's Ran Out
1) are you sure they are 30x90cm CERAMIC?
2) even if you tank the skimmed plasterboard it will not take the weight of tiles of that size - in line with B.S. - it is still only 23kg per metre sq.
3) best option is as above. Get back to studs and use waterproof boards such as Wedi or similar, tape all joins.
Good luck and enjoy the forum.
Ollywest
Mapei UK Marketing
833
Hi all
Any advice welcome.
"We would advise that best practice would be to tank the plaster using a tanking system such as Mapei Aquadefense incorporating Mapei Mapeband. However the plaster must be finishing plaster and completely dry.
The maximum recommended weight limit for finishing plaster is 20kg/m², therefore to direct tile to this you wouldn’t want the weight of the intended tiles to exceed 16kg/m².
To install heavier tiles in this type of application it would be advisable to mechanically fix tile backer boards and tank these to receive the tile."
Bill
I have recently fixed 900x300 ceramics.....
Reply to Preparation for shower tiling in the Tanking and Wetrooms area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
