Preparation for shower tiling
As above but no tanking coat required just all corners+!
Cuts with a knife.
Light to handle.
Cost effective!
Hi all
I have a new build extension and the bathroom has been lined with green plasterboard then skimmed by the builder, looking for any advice on preparation for tiling a shower area? Seems it would have been better for it not to have been skimmed, can the plaster be tanked or primed, or overboarded with hardie-backer? Tiles will be 30 x 90cm ceramic.
Any advice welcome.
"We would advise that best practice would be to tank the plaster using a tanking system such as Mapei Aquadefense incorporating Mapei Mapeband. However the plaster must be finishing plaster and completely dry.
The maximum recommended weight limit for finishing plaster is 20kg/m², therefore to direct tile to this you wouldn’t want the weight of the intended tiles to exceed 16kg/m².
To install heavier tiles in this type of application it would be advisable to mechanically fix tile backer boards and tank these to receive the tile."
Tanking and Wetrooms
Ollywest,
Time's Ran Out,
Ollywest,
Time's Ran Out,
