Discuss preparing painted walls in the Canada Tile Advice area at TilersForums.com.
Guitardedleon
I have tried and tried to shift this bloomin paint from the walls!
used a steamer, it works, incredibly slowly and with a huge amount of effort
getting around 0.5sqm every two hours!! well would be had the steamer not packed in!! :mad2:
in this situation what would a professional do?
I do not want to sand the walls down, the room is too small to warrant the amount of dust.
the paint is a silk by the looks, quite resilient and only the one layer on plaster.
can I tile onto this paint if scored to high heaven?
if not, how am I to get this off? I can feel the frustration building to near boiling point! :(
Guitardedleon
its very tough paint whatever it is. I'm not convinced it is gloss though as it is coming off, albeit slowly.
Ill have another go in the morning, in fact i'll pop a photo up too.
I know tiling onto paint is a no-no & would rather a job done properly, even if it means a ton of extra work!
If it is gloss however, How would you remove it?
Guitardedleon
If the paint is on and it's not coming off dare I say it leave it buy a 115mm diamond flat disc from screw fix put it on a mini grinder go over the whole lot to give it a key sponge it clean and tile it I use a water based paint tanking system for pools and tile on it all the time
oh it's on alright lol.
i don't have a grinder & would rather go without the added expense right at the moment for this job
on my larger rooms & other house I wouldn't mind.
i do have a multi tool if there is a suitable attachment?
tried washing the walls with some detergent & water ..didn't budge what so ever , whereas a Matt emulsion would wash off.
so it's likely a vinyl silk.
ps. Mike, noticed you are from aber! Lovely little place that! Used to go as a child.:thumbsup:
mike1979
yes aber is not too bad I used to work in cardiff for Taylor tiles on cowbridge road but everyone has different views on paint I've tiled over paint and not had any comebacks if it's shiny or very smooth you need to either sand it a little bit or use a wire brush then sponge any dust off let it dry bond it with acrylic sealer not pva that's crap and away you go
area tiling
523
n.ireland
I wouldn't be using a steamer it will only weaking your plaster skim coat ! Get yourself a make shift scorer , by cutting the handle of an old saw , and let the teeth on the saw do the scoring of the wall by using an downward or upward motion , pulling it through the paint ! Then remove the dust and prime!
Guitardedleon
Good tip, thanks.
What would i prime with?
Guitardedleon
Always Try to match your primer with your adhesive, if not then Any sort of acrylic primer , by bal weber, Dunlop , mapei or whatever your local supplier stocks, as long as it's not pva !
I have a load of everbuild SBR here left from sealing the sides and bottom of some wbp
Is that suitable?
mike1979
Yes I only use SBR have used it for years good all round primer/sealer
Sbr is amazing I mix it with cement and re fix pool coping and wall coping stones the stuff goes off like iron so you could use sbr instead of acrylic sealer can you if so I will stop using acrylic as I have loads of sbr
Reply to preparing painted walls in the Canada Tile Advice area at TilersForums.com
am tiling a en suite tomorrow and the walls painted, tried scraping as I usually take it back to...
20K
Hi there :) I'm hoping some of you lovely people can help me. I'm wanting to tile 3 walls in...
5K
Before I start tiling the walls have a rough painted surface going into a shower area. Shall I...
8K
Peter
Hi All. I have just had most of my apartment tiled, the walls are all freshly painted the week...
Qwerty
Q
am i right in thinking on a painted wall a bit of good old fashioned scraping is the only option...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
