Jimbobble
Hi,
I've got a kitchen to do next week & am laying 330 x 330 ceramic onto a mixed concrete & wood floor (used to be a chimney breast where the concrete is).
Just a quick question about Cement particle / Marmox / No more ply as I've never laid it before. Will 6mm do and then screw into floorboards after a quick skim with adhesive? I'm going to use 25mm screws after priming floorboards.
I'm assuming the floorboards are 20mm thick at their thinnest so a 25mm screw through a 6mm cement board & a 1 or 2mm skim of adhesive shouldn't be poking through at all should it? I'm probably being overly cautious but am concerned about pipework or wires under the boards! The house was built in the 50's & I know from days working as a builders' labourer that any multitude os sins could be hiding down there.
Any advice would be appreciated here,
Thanks,
J.
Thanks,
J.
