Discuss Prepping Floor boards / No More ply in the Canada Tile Advice area at TilersForums.com.
Jimbobble
Hi,
I've got a kitchen to do next week & am laying 330 x 330 ceramic onto a mixed concrete & wood floor (used to be a chimney breast where the concrete is).
Just a quick question about Cement particle / Marmox / No more ply as I've never laid it before. Will 6mm do and then screw into floorboards after a quick skim with adhesive? I'm going to use 25mm screws after priming floorboards.
I'm assuming the floorboards are 20mm thick at their thinnest so a 25mm screw through a 6mm cement board & a 1 or 2mm skim of adhesive shouldn't be poking through at all should it? I'm probably being overly cautious but am concerned about pipework or wires under the boards! The house was built in the 50's & I know from days working as a builders' labourer that any multitude os sins could be hiding down there.
Any advice would be appreciated here,
Thanks,
J.
G
GoneGuy
When I use no more ply on floor boards, I make sure the floorboards are screwed down and secure, sweep the floor then use the mega strength glue on the back of the cement board and screw in 25mm screws then put a bead of mega strength glue along edge and but up next board. Make sure you stagger the joints.
If your to unsure have a look at the video on their website.
Reply to Prepping Floor boards / No More ply in the Canada Tile Advice area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
using no more ply 6mm boards and screws. screws will not go flush. staying slightly proud
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 2 1.2%
    Votes: 5 3.1%
