Discuss price query in the British & UK Tiling Forum area at TilersForums.com.
Time's Ran Out
me too ! here are the reasons
1. cutting, most porcelain tiles are considerably harder to cut than ceramic and genrally larger format therefore require different tools than standard ceramic tiles,these are more expensive than the bog standard ceramic cutters and some porcelain cant be cut on a slide cutter and needs to be wet cut therefore more time consuming ,time is money
2. drilling as doug said drill bits dont last long and are pricey and you cant use a hole boy on porcelain
3.rectified edges are more unforgiving than the cushioned edge of a ceramic tile and I would argue the standard of your work needs to be higher on porcelain work
4.special adhesives and grouts,all the adhesives and grouts will need to be flexi and flexi adheives are more expensive
I'd certainly agree with points 1&3 if we are discussing tile fixing prices. But all this extra talk of drilling holes and flexible adhesives are additional costs to be included in an estimate and should not be the basis of a chargeable rate for fixing tiles.
dagger
i used to have seperate rates for different materials,
thats kind of faded away now, i do charge more for mosaics and geometrics.
but the hole drilling issue, you have to drill "certain" holes to fit the tiles, so that should be included in your M2 rate, extra holes i.e soap dish are chargeable as an extra!
IMO.
Reply to price query in the British & UK Tiling Forum area at TilersForums.com
Hello one and all, I have a 240m2 floor tiling job to price, including a tile upstand edged with...
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
price query
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
