Discuss Prime Plasterboard before tiling in the DIY Tiling Forum area at TilersForums.com.
Hi All,
I decided to strip all of the old plasterboard off the walls in my bathroom (as opposed to overboarding) and will be installing new plasterboard.
I will be tanking the shower enclosure with the Bal WP1 kit.
I will be fitting 600mm x 300mm porcelain tiles. Do I need to prime the plasterboard before tiling? If I do, can you recommend an appropriate primer?
Thanks in advance.
SJPurdy
Thanks for replies. I was thinking of using Bal APD primer?
Is this a good primer and are there any particular adhesives that work well with this?
If you are unsure why not stick with one manufacturer for primer, tanking and adhesive? that way they should have been designed to work together.
Time's Ran Out
From the original post if your stripping out the old plasterboard and tanking and using 600x300 porcelain, why not just replace the walls with Wedi boards and do a better job!
For a shower enclosure the extra cost cannot be much but for peace of mind it must be cost effective.
Plasterboard+primer+tanking kit v Wedi + tape.
Reply to Prime Plasterboard before tiling in the DIY Tiling Forum area at TilersForums.com
Hi guys, had some great advice here before so thought I would ask here for advice again...
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Carmarthen
DIY Tiling Forum
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
