Hello
I'm about to start tiling my downstairs toilet (the walls) and would be really grateful for some advice.
Do I need to prime the walls before tiling and if so do I need to use undiluted or diluted primer (I have BAL Acrylic Primer)? The surface is a mixture of mostly old plastered walls (which I've spent sodding weeks scraping all the old paint off), one plasterboarded wall that had been skimmed over in the past (the paint was a lot more difficult to scrape off here so I'm hoping I've removed enough paint from this wall to tile over) and a bit of boxing in with plasterboard.
Or should I prime some surfaces with undiluted primer and other surfaces with it diluted?
The tiles I'm using are those cheap bumpy ceramic tiles (33x25cm) with some glass mosaics for a border (I have a question about mosaics too, but I'll start a new thread for that).
I have some ready mixed Mapei Ultimate showerproof adhesive, but there's no guidance on the tub about priming walls. I'm happy to change the adhesive though (I've read mixed results about it).
Thank youl
Thank youl
