Discuss Problems with peeling tanking in the Australia Tiling Forum area at TilersForums.com.
jonnyc
Just been using two different tanking kits.
both on to plastered walls.
first one was Mira 4180 primed as per instructions on to dry Plaster Left to dry overnight . Next day applied two coats Mira multi coat.following day tanking looks fine but if you geta scraper under it you can peel tanking liquid and primer straight off the plaster.
another bathroom same plastered wall.primed as per instruction with Mapei primer g followed by ccl tanking liquid .same drying times same result.
never tried to peel it off before so maybe this is normal.
anyone found this.
anyone found this.
Im not going to ask a JOTY winner if he applied it right, I also have found the same problem with a Mapei tanking kit I used lately. I let it dry for an additional 2 days and it seemed fine. I put it down to the weather.
Used to use the mappai tanking and other latex/paint types. Always felt that they didnt stick that well. Last few showers I habe been using the ardex kit. Put that stuff on anything and you won't get it off .
I find the ardex 250 tanking kit the best about. Just wish I could find it locally.
beanz
Berkshire
anyone found this.
Can I ask what made you take a scraper to it? I can't say I've ever tried to do that, so no idea if that's normal or not!?!
jonnyc
No reason for trying to peel off.just thought I would see how well stuck.bit of a shock.
strange thing is that on sera of wall that had only primer on it ,primer was well stuck to wall.
only after tanking liquid applied and dry could I peel primer and tanking off wall.
you can tell that primer come off as so porous and wet finger discolours plaster immediately
Reply to Problems with peeling tanking in the Australia Tiling Forum area at TilersForums.com
Hi, I am a keen DIYer and have chosen an Impey Aqua Dec 4 and waterguard tanking kit. The Aqua...
23K
Deleted member 57709
Hi again Last week several of you helped me out with advice for a wetroom floor. There were a...
6K
Dumbo
Looking for a bit of advice re wetroom installation. I have completed a few wet rooms and have...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
