Discuss Problems with Underfloor Heating Cable in the British & UK Tiling Forum area at TilersForums.com.
Mark02
Hi Mark
Have you asked the company who sold you the product to come and look or explain why its not heating up correctly? I would also speak to the manufacturer of the heater to ask their advice. Did u buy to heat room or floor? What wattage is the heater?
Edd
Yes I have asked the company they cant see why its not working. According to the company it should heat the room, although we just bought it to heat the tiles. Its a 400 watt cable so should have ample power in such a small room. The wire covers 95% of the floor.
Mark02
It sounds to me like.
A. Cement board, not Insulation used.......so more heat lost downwards.
B. Probe positioned too close to heating cable, causing floor to constantly turn on/off and never heating to max temp.
Who installed UFH anyway??
It was installed by a a qualified electritian on a 6mm tile backer board. This formed a layer of insulation with a concrete polymer over the top. I have sat and watched the thermostat, it never turns off. Just to check I took out the thermostat last night and wired directly to the heating cable and the same thing happened?
Thats why im thinking of wriping it all up and putting down 30mm of insulation board?
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
This is insulating tile backer board with a cement face.....
And.... I can't find a picture of the type of board that is pretty much cement-only with some mesh in. I thought wedi board did it but their boards seem to be like marmox etc now by the looks of it.
Is it the insulating type board that has been used like in the picture above?
If it is a problem with the probe, and your thermostat has an air sensor too, you might be able to disconnect the probe from the stat just to let it run with the air sensor only to see if that heats up to a higher temperature. Though you saying it doesn't switch off at 26 degrees and keeps trying to get warmer suggests it is an insulation problem or just underpowered.
You should be running around 150 watts per square meter if your heating was 400 watts total and the room is 2.6 square meters. That's about right for heating a room providing you have insulation directly under the cable.
The 10mm of levelling compound, then a few mm of tile adhesive, then tiles of the thicker variety might have been better with a 200 watt per square meter system instead. They're normally used in conservatories and the likes, or in instances where no insulation can be used due to floor heights etc.
kilty55
1,113
edinburgh
hi mark have you contacted techinacal support from the manufacturer regarding this?
i installed a mat last year...a make i wasnt used to installing i may add and we couldnt get the temp past 20 degrees it seemed to max out......called technical support and after a few simple programming issues it seemed it was set on the wrong setting.
none of this was present in the instructions either i may add so may be worth a call to manufacturer not the retail outlet if you havent done so already
Mark02
The board I bought is described as follows
Tile Backer Boards are high performance, reinforced, insulation boards made of extruded polystyrene, this has each side coated with a fibreglass mesh embedded into it, and a cement polymer mortar coating is applied to both sides.
Tile Backer Boards are waterproof- rot proof, provide thermal insulation, and also have acoustic insulating properties.
Tile Backer Board are ideal for two primary purposes; as a superior waterproof surface to fix wall or floor tiles and as a first class heat insulation for underfloor heating systems. Heatstore insulation boards are particularly suited to underfloor and under tile heating applications. Installation below underfloor heating systems on an existing un-insulated, concrete or timber sub-floor will greatly reduce heat up time and running costs.
I am running out of ideas i really dont want to have to rip it all up and start again.
Mark02
I have sent back the thermostat to the compant. They seem to be quite reputable, they are sponsors of the forum and seem to of been reccommended on this site alot. They have gone through the controls with me, but cant find any problem. My only hope is that its a faulty thermostat. However I have wired the power supply directly to the heating cable bypassing the thermostat. The same issues are still present.
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
That is the good stuff like in the picture. So I'm lost too.
Reply to Problems with Underfloor Heating Cable in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
