Discuss Push Button or button press for toilet loo wc in stone or porcelain wall tiles in the British & UK Tiling Forum area at TilersForums.com.
Deleted member 1779
You would think that installers working with expensive porcelain, granite, stone or marble tiles would take a bit of pride installing simple items such as a button push for a loo. (I know all the pro installers on here would do a great job)
A button push or
actuators are used for flushing toilets which have concealed cisterns.
The reason to conceal the cistern is to give a bathroom a minimal contemporary clean line.
Its a simple device comprising the main unit, a rubber washer and plastic screw. There is also a rubber blow pipe which is connected to the back of the unit to connect to the main cistern.
A simple hole is all that needs to be drilled into the stone, granite or porcelain surface to give a perfect result.
But what I saw the other day made my blood boil. Some installer has decided to hack out a crude hole into granite, and then to cap it over with a white plastic piece of guttering barge board.
I kid you not....
Now instead of an elegant simple button push the owner is presented with an ugly botch of a job.
Whats the point of paying over £40psm for granite tiles to let the installer get away with that!
I think its time for me to do a quick article on how easy the result is to achieve.
Camera is on charge....
cornish_crofter
There's nothing wrong with that Richard:lol:
And, anyway what are you doing going into the gents with a camera?:whatchutalkingabout:whatchutalkingabout
Seriously though, it wouldn't have taken long to drill the hole out. I used the 30mm drill bit recently to accomodate 2 towel rail pipes coming out of the floor. The holes are large for the pipe because I had to accomodate the stop ends, or flood the place whilst trying to lay them:lol::lol::lol:
I've got a couple of chrome collars on standby when the job's nearly finished to tidy up the pipes. What I wanted to achieve is to do away with that nasty cut out to the back of the room that you often see in bathrooms.
cornish_crofter
I've found with those push buttons that you get very little cover plate to conceal your hole, the ones I've done recently only give you a couple of mm from the body of the flush system to the edge of the plate, luckily one of my bits is just the right size!
.....and if you're a couple of mm out, you're screwed!
Deleted member 1779
This is a button push we did for a client. It needed to be fitted over three tiles. Break any of them and its £80psm plus refitting !
Close up of a 50mm Button Push in Porcelain tiles with a diamond tile drill.
And This is the room it was installed in...
No its NOT a prison cell.... This is a luxury bathroom fitted with 600x300mm porcelain tiles thankyou!
Reply to Push Button or button press for toilet loo wc in stone or porcelain wall tiles in the British & UK Tiling Forum area at TilersForums.com
11K
Rizzle from the Portizzle
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
42K
Hello. My first post. After having good search, these tiling forums are the best I have come...
I
Hi there, I'm new here, and I'm not a tiler. I would be grateful for some advice on sorting out...
Gazzer
I've just tiled my kitchen splashback and for a first-time job I'm very pleased with it...
12K
Deleted member 1779
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
