I'm Stuck - Wish My Tiles Were
My use of that word was very loose wider...Maybe I should have chose a better term.
Clarity on tiling options in moving forward would be available after a site visit.
Im your job above... Did you have to remove an old floor... Any slc around the island?
🙂 was not a dig at you cam .
But we have all had to rip floors up with kitchens in and re do them, not every job is a nice empty flat square room 😉
Im just trying to give the chap options , which will give him a good job without ripping everything out, unless this bloke is a upstanding human and coughs up over 20 grand matt will be out of pocket , A LOT 🙁
As for my job, no ripping out, it was tiled by myself over ten years ago, nigh on 70m2, no kitchen in when tiled 1st ,the bloke tried taking one up, was solid as a rock, so we matted with .85 tilemaster matting and tiled in porcelthin so it didnt raise it to much
I genuinely feel sorry for the guy (and yourselves obviously), he's gone in way above his depth of knowledge and experience and it's gonna cost him. Hindsight is a wonderful thing and I'll bet he's having sleepless nights now just wishing he'd got an experienced tiler to do the work.
Edit that, the island was placed in , bloody joiner made a start before i tiled it for some reason, he was a bit mental , everything was 120mph with him, rough as a badgers arse but he got loads done 🙂
Personally I wouldn't let him redo it. He's not skilled in that field. End of.
Not sure how to address that to him mind if i were you.
Perhaps with some guidance he can do the job properly?! Maybe? Not sure.
Definitely all sensible options (no jam or squirrels) will still be for consideration and the pulling up around the units is possibly an option. Not fussed if the tiling under cupboards is crap - won't see them until my missus wants another kitchen. Just thinking how much easier if kitchen dismantled and stored. No cutting under units. Units won't be covered in crap (don't give me dust sheets, they never work). At the concrete end there're big bifold doors with barely a lip above the floor. Level a bit tight here and to relay floor the adhesive sticking the insulation boards may need hacking or grinding off. This was a bed with a notched trowel so he's obviously heard of that quaint method. All going to be easier without working round and under things.
The 20 grand figure is what I'd be looking at if its not done right now and there's a disaster in a few years and a similar kitchen needs to be put in. That would be if the floor failed and had to come up, an end panel or two got damaged and couldn't be replaced. The stone cost just shy of two grand fitted and might, just might, be removable. The kitchen fitting was another two so unlikely to be much more than four to take down and put back up. New UFH and insulation is about one grand. Most of the tiles should be reusable. Don't know what it'd cost to put in an expansion joint (is that a case of cutting down between the membrane and the timber and putting in rubber or Silicon?). Then there's the cost of one of you gentlemen to do the work (don't think he'll like that but would you have him do it again?). Reckon it'll be well under 10 grand. His fee was 50 for all the work he did. I don't know his margins but He had hardly any
The 20 grand figure is what I'd be looking at if it's not done right now and there's a disaster in a few years and a similar kitchen needs to be put in. That would be if the floor failed and had to come up, an end panel or two got damaged and couldn't be replaced. The stone cost just shy of two grand fitted and might, just might, be removable. The kitchen fitting was another two so unlikely to be much more than four to take down and put back up. New UFH and insulation is about one grand. Most of the tiles should be reusable. Don't know what it'd cost to put in an expansion joint (is that a case of cutting down between the membrane and the timber and putting in rubber or Silicon?). Then there's the cost of one of you gentlemen to do the work (don't think he'll like that but would you have him do it again?). Reckon it'll be well under 10 grand. His fee was 50 for all the work he did. I don't know his margins but He had hardly any
(Keep hitting post by mistake) hardly any labour and other than steels and velux windows, and roof tiles and lead, he was paying only for basic building materials.
So if he only made 20 grand on the job or 15 even, if it costs him say 7 or 8 to put it right he's still made something. Appreciate he's got to eat and put diesel in the van and what not but he won't actually be out of pocket.
My dog's called Trevor,
Dan,
Dan,
