Pva Versus Primers | Always Use A Primer When Tiling, And Not Pva
Oh the arguements i have had (especially with no-it-all-builders) about the use of PVA!! Trouble is a lot of these DIY programmes still advise the use of PVA as a sealer.
The pva from b and q even says on the bottle ideal for prep for tiling 🙁
I think all the PVA Bottles from any manufacturer say the same.... it doesn't help when places like Niccobond have there primmers labelled as PVA (big red letters) even though it is not a PVA. how then are we supposed to get this through to someone when this type of thing is going on? Does my bloody head in, i seem to get this down here every other day with someone or other
I always explain the difference in pva and primer to someone questioning it.. The usual pva doesn't soak into the substrate and Sellotape doesn't stick to paint scenario normally suffices
Yeah snap mate, i always get the same old 'i been doing it like that for 25 years and never had a problem answer' though.... to which i always reply 'well you have been doing it wrong for 25 years then and have you been back to see any of your old jobs recently'. Just turns into a row, i tell the customer to go away and check it out for themselves and when they do they then realise i was right......... To which the builder will say 'yeah but that's because they aint diluted it down' aaaarrrrggghhh give me a gun lol
I recently went to a job that had been done half height and the client changed their mind and wanted it full height so I decided it was easier to strip it off and start again I didn't tile the first attemp I stuck a trowel behind the trim and the lot came off with no effort the walls were clean as a whistle I found out who done the tiling on site and asked them if they primed the wall the reply was well ye I always pva the walls up
No surprise 🙂
MANY PEOPLE THINK THAT P.V.A. IS OK AS A PRIMER ON WALLS AND FLOORS SO I THOUGHT THAT I WOULD LET YOU SEE THIS " LINK " AND HOPEFULLY IT WILL ENLIGHTEN SOME NEWCOMERS OR EVEN EXPERIANCED TILERS AS WHY NOT TO PRIME SUBSTRATES WITH P.V.A. INSTEAD OF PRIMERS.........DAVE.....
P.S. I always prime with primers and this will show you why!!!!!!!
PVA - Why you shouldn't use it as a tiling primer
I have to give guarantees for my work (many of these projects are commercial such as sports centre showers and changing rooms). For me to be able to give guarantees I need to follow strictly the specification of the adhesive manufacturers.
Ardex, BAL and Nicobond are the three suppliers I use most. Their products are similar in many respects, sometimes one will make products the other don't, and I also find some of there products more useful in different applications. All three of them have one thing in common, they all specify that under no circumstances may PVA be used before using any of their adhesives. If you do all guarantees are void.
OK why then? Well I asked this question to Ardex when I once had problem, I'd tiled a bathroom that had been constructed in 25mm Marine ply. Thinking he was doing the right thing, the builder got his guys to seal the ply with unibond PVA...I wasn't aware of this.
I tiled it and 6 months later every single tile fell off the ply, the adhesive solidly stuck to the tile but came clean a whistle off the ply.
We had Ardex Technical down to the site to compile a report, the basis of which was it's the PVA that causes the problem.
When you treat a surface with PVA it partly soaks in and partly sits on the surface of the substrate much in the same way as wallpaper paste.
If PVA gets wet it becomes slightly live again, it doesn't completely return to it's liquid state but it becomes sticky.
When you spread tile adhesive onto the wall, the water in the adhesive makes the PVA live and stops the adhesive from penetrating the substrate and providing a mechanical grip. Basically your tiles, grout and adhesive are being held to the wall by a thin layer of PVA.
Most tile adhesive works by crystallising when it sets (some are slightly different such as epoxy based ones) but generally they all work the same way. Once the adhesive starts to set crystals from and expand into any imperfections in the substrate surface (at a microscopic level) to create a grip. PVA stops this process by creating a barrier between the substrate and the tile adhesive.
Ok so what's the difference between this and Ardex or BAL primer, well basically the tile manufacturers primers soak right in to the substrate and stop the sponge like "draw "effect but they don't coat the surface in any way, they are an impregnator as opposed to a barrier. They also stop a chemical reaction occurring between the cement based adhesive and a plaster substrate, a known problem know as "Ettringite failure"
I hope this clears up any misunderstandings.
So only use PVA before tiling if the adhesive manufacturer specifies it in the instructions.
A while ago I wrote a post for another forum which explained the reasons behind not using PVA as a tiling primer, it is posted below for your information, I've been asked to copy it to various other forums and thought it might be useful here also. I hope it is of some help.
Oh and if you do require a primer then use one suitable for the adhesive you are using, such as BAL APD or Ardion 51.
I'm a professional tiling contractor, I now mainly specialise in natural products but over the years I've stuck up (or down) every type of tile there is.
Ardex, BAL and Nicobond are the three suppliers I use most. Their products are similar in many respects, sometimes one will make products the other don't, and I also find some of there products more useful in different applications. All three of them have one thing in common, they all specifiy that under no circumstances may PVA be used before using any of their adhesives. If you do all guarantees are void.
When you treat a surface with PVA it partly soaks in and parlty sits on the surface of the substrate much in the same way as wallpaper paste.
Most tile adhesive works by crystalising when it sets (some are slightly different such as epoxy based ones) but generally they all work the same way. Once the adhesive starts to set crystals from and expand into any imperfections in the substrate surface (at a microscopic level) to create a grip. PVA stops this process by creating a barrier between the substrate and the tile adhesive.
Ok so whats the difference between this and Ardex or BAL primer, well basically the tile manufacturers primers soak right in to the substrate and stop the sponge like "draw "effect but they don't coat the surface in any way, they are an impregnator as opposed to a barrier.
Bumping this thread for newcomers to read.
the original link is working anymore but there is loads of similar info all over the internet.
Hope this info helps.
enduro,
Dave,
enduro,
Dave,
