Scott
Thats right scottiecom just the back and edges. Although it depends on your adhesive manufacturer, some say prime the face and some dont. You need to read the instructions to make sure.
Interesting thread. Questions about priming- In the UK do you prime every surface before you tile or only wood and plaster surfaces?
Over here the only time I prime a surface is before applying self leveling cement. Also if tiling over gypsum based self leveling (we call it gypcrete) installed by others.
Otherwise just use a latex modified mortar that is designed to bond to the particular substrate. We have ANSI 118.4 products that are latex modified for bonding to masonry surfaces and ANSI 118.11 for bonding to wood surfaces. They are adding ISO labels, Mapei has them already.
Most of the time I am setting over existing concrete. If it is a plywood floor we go with cement board/hardi/or Ditra over it.
For walls in showers I go with cement board but apply a surface applied liquid waterproof membrane. Usually the only time I am bonding to drywall(plasterboard) is for a kitchen backsplash.
Is the sealer to improve the bond, or to prevent the substrate from pulling the moisture out of the mortar too fast, or a combination of the two? Thanks.
