pva
Freshly plastered walls, especially if your tiling onto 'bonding' type plaster.
Also, wooden surfaces. 🙂
Plastered walls if using cement based adhesives - use recommended primer not PVA
Freshly laid screeds - helps reduce dust and aids adhesion of tiles.
Anhydrite Screeds - always prime -remove laitance first ( top flaky layer )
Wood - usually.
Mapei sell a number of tub adhesives which do not require primer onto plaster.
Also many of their flexi adhesives do not require primer onto wood or some concrete surfaces.
Just to add my my 10p worth. Depending on what company adhesive your using. Most have spec sheets you can read and decide from there. If in doubt ring company up. Different adhesives have different additives added to them so difficult question to answer.
The only time you could get away with using pva would be on a concrete floor. PVA is only a sealer, not a bonding agent!
what is the best bonding agents i use the bal but was wandering if anyone got better stuff or better prices i ve paid £12.99 to cover about 6m2🙁 . Although saying that i am not trading yet and have to pay the same as the public
Always use the adhesive manufacturers recommended bonding agents. 🙂
Ardion P51 (Ardex) is good stuff sparky, but you should only really use a bonding agent that suits the muck your gonna use.
sorry to sound daft here lads but ime new to this game whats the differance between a bonding agent and a primer
pva
Tags Tags
pva usa
clmcg123,
scrafton,
clmcg123,
scrafton,
