Discuss question for gaz @tops in the British & UK Tiling Forum area at TilersForums.com.
GazTech
is the 6mm hardibacker board for floors suitable surface for 12mm thick marble tiles its a bathroom floor and existing floor is chipboard. and another question what is the 6mm board equal to in terms of ply thickness
On chipbaord flooring 6mm is ok to use with normal flex adhesive,however onto T&G no less than 10mm backer board will do.Most bathrooms are small enough that a 2 part flex is cheaper to use than backer board and standard flexi,labour cost for fitting boards taken into consideration.Can't really compare backerboard to ply,must only go with manufacurers recommendation hope this helps Guy
Reply to question for gaz @tops in the British & UK Tiling Forum area at TilersForums.com
  • Question
What would you Pro’s do? A new extension has electric UFH in the screed which has been brought...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Tags
usa
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
