Discuss Questions. . . in the British & UK Tiling Forum area at TilersForums.com.
slikt
Hi, been tiling on and off for many years. My question is, i'm about to do my kitchen floor and I wanted to check what i'm about to do is the correct way as it'll work out a very costly mistake, I just wanted to know about the correct procedures :)
The floor is concrete with patchy SLC that is under vinyl tiles, and i'm looking to install UFH mats and porcelain 600x600 tiles. . . so. . .
1. Prepare sub floor with primer
2. Use flexi adhesive to fix insulation boards (are they always necessary)?
3. Fix UFH to boards
4. Use SLC to cover entire area at a 2-3mm thickness?
5. Use Rapid flexi adhesive to fix tiles.
Can you guys recommend the right products, I normally use BAL rapid set flexible?
As said, I need to get this right as there is alot or prep work and an expensive mistake if I missed something out.
Any advice and comments are more than welcome and thank you in advance. . :)
Reply to Questions. . . in the British & UK Tiling Forum area at TilersForums.com
    • Friendly
Questions. . .
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
