Discuss Raimondi Berta Grout Washing Machine in the Australia Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,089
1,323
Staffordshire, UK
View: https://www.youtube.com/watch?v=PQ-MXRJTp6s
Raimondi BERTA Grout Washing Machine
Electrosponge for cleaning grout (cement based or epoxy resin) from floors: Terracotta, porcelain, double-fired and single-fired
tiles, marble, clinker, porphyry, natural stone, quarry tile, treaded tile, etc. during the grouting phase.
• Does not pull grout from the joints. Easy handling, suitable for use even in small areas.
• Performance: 800 - 1500 s.f. per hour in general.
• Sponge rollers can last from 1,600 - 10,000 s.f. ( Based on material; abrasive quarry tile - smooth glazed tile)
• Moisture level of the sponge roller is adjustable via the pressure adjustment lever. Easy-to-use pressure adjustment lever also
adjusts the front wheels.
• Easy-to-replace sponge roller thanks to the magnetic “quick clutch” system.
• Water is fed to the roller via a foam-reducing belt (no pump to clog up).
• The handle folds down for transport or storage, and its ergonomic design are fully adjustable for height and angle according to the user(s) needs.
• Die cast aluminum body reduces weight while increasing overall strength.
• Easy-to-remove water-tank (15 liters, 4 gal.) is made of impact resistant plastic to reduce breakage.
Standard with: sponge roller for cement based grout, anti-foaming liquid, user and maintenance manual.
Anybody considering one?
Reply to Raimondi Berta Grout Washing Machine in the Australia Tiling Forum area at TilersForums.com
My goodness - what a palaver!! So, I've been tiling my own wet-room with TOPPS 60x30 Polished...
9K
Billy Hunt
First time I've seen these, local supplier has just got them in....anyone tried these. Leveling...
31K
Italy
I
E
Hi. I'm afraid I'm not allowed to post links or pictures so you'll have to visit these URL's...
Raimondi Supertitina cleaning and grouting machine: - dual speed; - 110V; - 600W; There are...
7K
rokokoko
K
Hi all, Have just finished tiling three rooms in house. Adhesive and tiles were set 48hrs ago...
5K
Rookery
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
