Raimondi BERTA Grout Washing Machine
Electrosponge for cleaning grout (cement based or epoxy resin) from floors: Terracotta, porcelain, double-fired and single-fired
tiles, marble, clinker, porphyry, natural stone, quarry tile, treaded tile, etc. during the grouting phase.
• Does not pull grout from the joints. Easy handling, suitable for use even in small areas.
• Performance: 800 - 1500 s.f. per hour in general.
• Sponge rollers can last from 1,600 - 10,000 s.f. ( Based on material; abrasive quarry tile - smooth glazed tile)
• Moisture level of the sponge roller is adjustable via the pressure adjustment lever. Easy-to-use pressure adjustment lever also
adjusts the front wheels.
• Easy-to-replace sponge roller thanks to the magnetic “quick clutch” system.
• Water is fed to the roller via a foam-reducing belt (no pump to clog up).
• The handle folds down for transport or storage, and its ergonomic design are fully adjustable for height and angle according to the user(s) needs.
• Die cast aluminum body reduces weight while increasing overall strength.
• Easy-to-remove water-tank (15 liters, 4 gal.) is made of impact resistant plastic to reduce breakage.
• Standard with: sponge roller for cement based grout, anti-foaming liquid, user and maintenance manual.
Anybody considering one?
