thegwads
hi all
doing a little floor today, bathroom upstairs, boarded out and screwed corrctly etc... anyhow using granfix 1 part flexi rapid set which i just used on a 55sq. meter floor no problems - although that house was cold so took a decent amount of time to go off.
any way, today first mix went off in about 15 minutes, 2nd mix which i did on the wet side took about 20 minutes to go off. using clean buckets, clean water etc...
turning out to be a ball ache on 5sq. meters with bath, loo, sink in the way.
can anyone suggest an adhesive, flexi, which doesn't set so quickly. need to be grouting same day, so need rapid set, but could do with a slightly better pot life!!
any suggestions
basically i will probably dry lay all of it tomorrow, cuts etc, then just mix up small amounts at a time, but really winding me up now!!!
cheers
any suggestions
cheers
