Guest viewing limit reached
Rapid setting slc
the difference between Level It and the Bal product is the depth of which you can lay it at - horses for courses if you need the added depth although personally, I would screed it myself in s&c if I needed 80mm build up and then use a green screed adhesive.
Andy wanted a leveler to go over ufh wires then tile same day, this is ideal for that 🙂
Rapid Level 30
Rapid Level 30 Ultra Rapid Setting Fibre Reinforced Flexible Self Leveller
• Tile After 45-60 minutes
• Apply impervious floor finishes after 90 mins.
• Excellent self levelling properties.
• Apply from 2-15mm in one pour.
• Ideal for Under Floor Heating Systems.
• Ideal for plywood and chipboard overlay
• Simply mix with water.
simples........i does what it says on the tin
Spot on julian, you can go to the front of the class and get a gold star..🙂
i do struggle to get TM products but popped into the suppliers today and they do both the TM and bal rapid slc.....so spoilt for choice ......I like the fact the TM drys quicker but bal can go thicker.....decision's , decision's.....
yes I do use CTD Lee, mainly because I get great service and price, as I'm sure if i lived up your neck of the woods I use your outlet, plus here these no other outlet's around of note.
I have tried some TM adhesive, well twice, but not the leveller. Don't dispute its good gear, how can I, it's liked and used by many a notable member .
Rapid setting slc
Andy Allen,
Flintstone,
Andy Allen,
Flintstone,
