Guest viewing is limited
Discuss Re-Grout or Re-Tile for limited DIYer in the British & UK Tiling Forum area at TilersForums.com.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Just out of interest; did you buy the house from the builder? I know it's been 8 years. But NHBC covers 10 years, it won't cover movement and settling damage of the property. Like cracks in plaster. This is what they would put the failed Silicon down to. BUT, i think it would be worth a shot trying to find out who did the tiling, installation and kick up a bit of a fuss over it not being right. You never know.
N
ngac
Thanks for your input.
Unfortunately its the only shower in the house so we need in on occasion.
Im actually going away next week for a week so ill rip up all Silicon on shower tray.
bleech the mould on tray and leave then seal when i return next week.
Ill replace shower and tiles together in few months.
Thanks for advice.
Stef
If you want a quick fix till you can afford to retile then i would Silicon all your grout lines, that way it should stop any water ingress.
I moved into my property 2 years ago & the upstairs shower leaked last year, the tiling is horrendous, i cut out all the old Silicon & siliconed every grout line & every where else that the leak could come from & its still water tight. Its not pretty.
I only done this as a temporary measure till i ripped the whole thing out.
Just saw the top post from Ali there, :mad2:
Ste-Armer
Hg mould spray is really good for removing mould, I would completely get rid of the mould, remove all the old Silicon again hg do a Silicon remover which is very good. Then re-Silicon.
Some of the grout in my bathroom cracked before I could afford to re-do it, so I just got a grout rake and scraped some of the grout and re-grouted. If there is cracked grout water will leak through and get behind the tiles then you could end up in a worse situation of the tiles coming off.
Reply to Re-Grout or Re-Tile for limited DIYer in the British & UK Tiling Forum area at TilersForums.com
Unfortunately the tiler did not follow the manufactures instructions for mixing up the two part...
I recently got several loose/hollow tiles rebonded on my bathroom floor. Having left with...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
