bureaucrazy
- 178
i wish to use 20cm square thin white glazed ceramic tiles on top of existing glazed tiles. this is on the walls round the bath, over which there is already a shower. the easiest option seems to be using the ready mixed tub of adhesive which also doubles as grout from unibond. will this stick to the underneath tiles ok? will the grout be ok for the shower area or should i use cement based seperate adhesive and grout? most of the wall is already tiled where the old shower cubicle was so i don't have time to hack everything off and render the walls so i just want to tile the bit further out than where the shower cubicle used to be . the existing tiles are on top of old tiles. thanks
