liammob
I'm currently tiling my bathroom using a flexible cement based powdered adhesive. It turns out I'm very slow at tiling (not a problem as I'm using standard set adhesive).
I'm currently on night shift but would like to do a bit of tiling before work, even if I knock up half a batch I would probably end up with quite a lot of waste. Is there an acceptable ready mixed tile adhesive I could use on the plasterboard wall? The wall isn't in the shower or bath and the tiles are ceramic 200mmx100mmx6mm . I would continue using the powdered adhesive on the shower and bath walls.
