Regrouting
P
pendleh
Hi there
Customer has existing tiling in hallway, although a cat has discoloured the grout. She would like black grout. How do I go about regrouting and then sealing the grout so this dosent happen again. Many thanks
Best Wishes
Howard Pendlebury
Hi Howard,
You need to take out the old grout with a grout rake or a Fein mutimaster, clean everything up and then regrout with your chosen grout. Black might give you nightmares for cleaning though!!!!!! Be aware it is a really sh***y job though and you will more than likely damage tiles with the grout removal tools.
There are sealants you can buy for the grout. Have a look in Topps at Fila stuff I think or Seal-Guard - they have a spnsored link on this site, look at the bottom of the page.
Grumpy
Thanks grumpy this website is ace! I know there only basic questions but Im making sure I do everything right. I envisaged taking the grout out. I have a fein multimaster so I might give it a go. It may well be as cheap to relay tile on tile. Im always going to recommend sealing grout to stop discolouration. Again many thanks to everyone for their help.
If the grout is just discoloured, but other than that in good condition, you could use a grout recolourant. No chance of chipping the tiles as you don't have to remove the old grout.
Hi there
Best Wishes
Howard Pendlebury
Get rid of the cat It'll save her a fortune
Put a blob of Silicon on the cats todger - Lol. Or better still, cover it in rapidset!!
Hi Wayne
I'll look into aquamix product it sounds just the job!
Many thanks for all replies.
aquamix do a grout colourant. not cheap but supposed to be brilliant. epoxy based as well so no need for sealer.
Hi Sorry guys logged in now!
Aquamix Grout colourant Pre-Treat Cleaner
[DLMURL]http://www.aquamix.com/products/pg_detail.asp?pdid=31748&pgid=8374[/DLMURL]
http://www.aquamix.com/products/pg_detail.asp?pdid=25042&pgid=8374
What I'll do is clean first then use the grout colourant. I think this is best solution for customer.
Best Wishes
Howard Pendlebury
Tiling Solutions 4U
If the discolouring results from the cat´s urine, it can smell terrible for a long time as the urine is deep in the grouts. I would be afraid that this will remain if the grouts are only recoloured, therefore I have the same opinion as grumpygrouter - regrout.
Regrouting
pendleh,
Leatherface,
pendleh,
Leatherface,
