Mike
what's the easiest way of removing dried primer off tiles? i do inevitably get some on the tiles and it can sometimes be a pain to remove. what do you use? i usually prime with primer g. cheers
Discuss removing dried primer in the British & UK Tiling Forum area at TilersForums.com.
I find hot water and a finger nail tends to work...
yeah i know bri, just sometimes i miss a bit and only see it when i'm grouting. i'll be a good boy and work cleaner seeing as there's no easy fixYeah that's the way!
Clean it up before it dries you messy so and so :lol:
depends if there's a masaic border going up, i'll just prime the bottom half of the room and tile it then prime the top half. i dont like to leave the primer too long before tiling.i get the bottom half and all the mosaics up before starting the topDon't you prime first and then put the tiles on Mike. :smilewinkgrin:
this time they're ceramics, i've done it now with a scraper as rich suggested. i was hoping there is a liquid cleaner i could put on a cloth to make it easier :smilewinkgrin:
Reply to removing dried primer in the British & UK Tiling Forum area at TilersForums.com
