removing dried primer
this time they're ceramics, i've done it now with a scraper as rich suggested. i was hoping there is a liquid cleaner i could put on a cloth to make it easier :smilewinkgrin:
I was hoping for the same easy fix when i chucked an entire bottle of the stuff all over the sanitary ware :lol:
I completely messed up today , misunderstood my job description. And i covered up some tile with primer t and mapei self leveler. Was about half way done covering it with a light coat before I was informed it doesn't get done. How do I remove it, can I?
One effective way to remove dried primer from tiles is to use a razor blade or a scraper tool. Gently slide the blade or scraper along the surface of the tile at a shallow angle, being careful not to scratch the tile. The dried primer should start to come off in flakes or small pieces. Make sure to keep the blade or scraper flat against the tile to avoid any damage.
Alternatively, you can try using a mixture of warm water and dish soap. Apply this mixture to the dried primer and let it sit for a few minutes to soften the primer. Then, use a scrubbing pad or a soft brush to gently scrub away the primer. Rinse the tile thoroughly with clean water afterward.
Always test any method on a small, inconspicuous area of the tile first to ensure it doesn't cause any damage or discoloration.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
