Discuss Removing efflorescence in the British & UK Tiling Forum area at TilersForums.com.
Branty
I don't think Kev was talking about cristalisation. Im sure he wouldn't recomend this.
As far as Im aware, and Im no expert. When you cristalise a stone, you create a hard shiney layer on top of the stone. If you use this to remove effloresence, and the cause of the effloresence is in the substrate, then all you do is lock in the problem
wetdec
You are correct on both counts I believe :thumbsup:
tiler
TilingLogistics
Bang on
The cause of the Efflorescence has to be solved otherwise its a finger in the dyke job. What is the point of getting rid of effloresence if just reoccurs?
Kev
Fact: If effloresence occurs in Natural stone and you wet grind, hone or polish it will reoccur.
Fact: You must establish the cause whether that be the DPM or anything else you need to stop the problem at source or you are wasting your time.
Effloresence can be sorted in any situation provided you deal with it in clear logical steps:thumbsup:
Kev
Reply to Removing efflorescence in the British & UK Tiling Forum area at TilersForums.com
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
I have dark brown tiles and brown grout in a shower (never again) that never looks clean. there...
Lizmetal
L
I had a new porcelain patio installed several months ago, and we have been struggling ever since...
Home owner here based in Surrey with a new Porcelain tiled patio. I need some advice about some...
5K
Alan johnson
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
