Discuss Removing flexi adhesive from floor in the UK Tiling Forum area at TilersForums.com.
Rich
As Doug says the ideal thing to do would be rip out the chipboard and replace with 22mm WBP ply and then over board this with a backer board. This would give you about the best substrate you can in that room.
If you cant do this then over boarding the chipboard should be ok as long as it is fixed down so that there is no bounce at all and you manage to get the adhesive off to give you a clean flat surface to lay the cement boards. Be aware that you must make sure that there are no voids under the backer boards.
Reply to Removing flexi adhesive from floor in the UK Tiling Forum area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
