Discuss Resin backed stone - adhesive in the Canada Tile Advice area at TilersForums.com.
...the mosaics are a worry. As well as the resin mesh they are mounted on a second mesh that seems to use a water soluble glue rather than the (probably) epoxy based backing. So the mosaics have both - you wonder if any of the tile will be in contact with the adhesive!
Ive fixed these cheap tiles lots of times. Ditra. Spf. Back butter. Watch out for tile sizes and out of square tiles. Are these internet bought tiles? Sample semt to customer in 10x10cm size showing a perfect marble.
In reality the 600x400 is veiny and in parts rough!!!! Held together with the resin back mosaic.
When wet cutting expect some to fall apart on the machine bed.
Reply to Resin backed stone - adhesive in the Canada Tile Advice area at TilersForums.com
