Restaurant floor
i tend to agree with Gaz for the addy and stuff but as for someones idea of 10mm grout lines halve it :thumbsup: Mike...
Make sure you don't let that grout go off on the tiles too soon. The GT1 tends to make the grout 'set' a little quicker and can be a maul to get off quarry's. Work to a meter or so at a time and wash it all off as soon as you've done your meter.
They are quarry tiles - how's best to lay these little bauties? I was gonna key the floor, prime with BAL primer, lay using BAL flexi, grout with W/J grout with GT1 admix in. Do the tiles nees sealing? If they do? Is it best to seal before I lay them, or between laying ang grouting? Will they cut on a flat bed dry cutter?
Many thanks guys, you are a fountain of knowledge as per usual
Will
Hi willbones, depending onthe make - I only have experience with Dennis Ruabon quarries - they don't need sealing. In fact the Raubon tech specs point out that they SHOULD NOT be sealed. If they are Ruabon quarries then look on to their site and look at their tech sheets or the whole tech spec manual. it gives a huge amount of info regarding specification, fixing and cleaning and the like.
You will need to register I think.
http://www.dennisruabon.co.uk/docs/tech-data-library-v1.2.pdf
Grumpy
just looked this one again quarry tiles are basically porcelain tiles like dorset stone but the traditional ones like plats Ruabon ect we always used to put a thin coat of boiled linseed oil mixed with white spirit but as Grumpy says they don't need sealing
if you dont know what a quarry tile is you you shouldnt even call yourself a tiler .
quarry tiles are made from clay mate and the darker in colour they are the longer they have fired them for some times called burnt clays oh and don't tell me there also different in colour because of clay type yeap we all knew it. Prep for them was to seal them with boiled linseed oil, but times have moved on so advanced impregnators are used. If there not sealed they will stain end of. Now if you want me to answer the question regarding laying them i will. They used to, and may companies still lay them in a screed due the difference in thickness now before laying them they sprinkled dry cement on to the wet screed then tap the quarrys down for grouting they would use mortar non of these fancy grouts we have today. which mr unregistered already knew !!!!
Any more questions
Restaurant floor
Tags Tags
floor usa
willbones,
Proper Job,
willbones,
Proper Job,
