Retiling wetroom advice on how best to proceed
This baby just arrived...
We were being quoted 8k plus for the job.
it will be available for purchase after I am done with it.
It is going to be an epic father and x2 sons project...
There will be an alcove in the shower area which we want to try to mitre, what resin would you guys recommend to fill the join, so that I can sand and polish the joint later?
Many thanks, Waluigi, my tiles which I will be mitring will be dark grey and bronze, would you know which colours from the polysoft corresponds to the colours I need?
thank you again. Does the mitred join need to be filled with resin, I will be using epoxy grout, can I not just used this to fill any gap? Then polish it?
I’m not entirely sure. I’d imagine that epoxy would be a whole world more complicated to work with but I might be wrong.
To an extent, polysoft is easy to work with, to shape, to cut, to sand, to polish and clean.
I don’t think epoxy would behave in the same way.
Tanking and Wetrooms
YT233,
Lou,
YT233,
Lou,
