Review: Rubi ND180 BL electric tile cutter..
Re: Review : Rubi ND180 BL electric tile cutter..
Thats the cutter i have Dave. Didn't like it a first but its grown on me now.
Hi everyone
I have the 180 BL cutter and although reasonably satisfied with it think the following could be improved, certainly for porcelain tiles.
1. water reservoir awkward to remove as you have to lift the machine up to bring it out at an angle thus pouring any remaining water over the floor.
2. guide difficult to line up with blade. guide screws soft and once you have taken it off a few times they get ragged and difficult to re-tighten.
3. fence not extendable so not so easy to cut the 600x300 tiles that i have.
I would be interested to know how to cut out socket holes, looks tricky to me!
cheers andy
Just un-screw the guard from the blade and plunge cut the tile over the top of the blade..
Hi Andy
I have a ND myself and in answer to your points:
1. Water resevoir IS awkward to remove - do you have a Lakeland Plastics near you. I found a plastic tray (60cm X 42cm) originally used for cleaning oven shelves, to sit the cutter in - job done.
2. Go to Ikea for replacement screws (the ones that screw wardrobes together - they fit perfectly) for the guard, but you should only need to loosen them to get the guard out
3. Nothing you can do about that am afraid - Only a basic line model.
As Dave says, unscrew the guard for socket holes.
I can post pics if needed.
Hope this helps.
Lawrence
Thanks for the tips chaps, it is a reasonable cutter all in all maybe the porc is at the top end of its limits?
I have ordered a new blade just in case.
Is it easy to hold the tile steady while doing plung cuts? Guess I will find out!
cheers
Andy
What is the fence!?! I'm just curious, as i'm thinking about getting one of these cutters, as my spindle is no longer straight on my Master Tiler, but i don't like the idea of being hampered when it comes to larger tile sizes..
Dave,
Dave,
