Discuss Ripping up a floor in the Canada Tile Advice area at TilersForums.com.
Gazzer
You are right Kev, before you can unscrew the boards you need to get the tiles up and actually find the screws. Not knowing how it was screwed wont help either. If the fixer did a 200mm centre pattern then it should help but as you say, the screw heads will be covered in adhesive.
You could take the destructive approach and get under the ply and lever it up. I would estimate a good 3 days with a labourer.
K
kaharrison9
If I go down the route of lifting I do think it will have to be the destructive route but like Brian says there is no knowing of what else may crop up like floor boards lifting, joists need strengthening, etc (there are a couple of cracks through the floor from the previous floor) and over 90 m2 soon could soon start adding up unforeseen costs. I have some photos i'll put on shortly
widler
1,328
England
To lift all tiles, in them different rooms,remove them all to a skip,lift all boards,(90m2 is nigh on 32 8x4 sheets)you would have to bar them up, take you weeks to uncover over 2000 screw heads :) :) :) then remove to skip,me id put 4/5 days in for 1 man and his lab .
If someone can do all that in 2 days on his own i will buy him a pint and treat him to a high class hooker :)
Reply to Ripping up a floor in the Canada Tile Advice area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Ripping up a floor
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
