Discuss Riven slate skirtings in the Canada Tile Advice area at TilersForums.com.
I
Ian
I hope you can see the photos clearly enough to help. I'm fitting a floor in there porcelanosa slate tiles next week and am doing 150mm skirtings, the customer wanted to use black metal trim bit I talked them out of that. Question is, what is the best way to finish them? Too uneven to profile (I think, haven't tried), maybe just polish the edge? Not sure.
ImageUploadedByTapatalk1364577675.926360.jpg ImageUploadedByTapatalk1364577698.893719.jpg ImageUploadedByTapatalk1364577717.026912.jpg
The Legend; Phil Hobson RIP
That looks spot on Phil. Did you do anything with the exposed edges? Hard to see from pics. (other than sealing them)
No Bri just grouted the top edge joints very carefully after sealing it then sealed again. I used decorators caulk on the joint between the skirt tile and the wall, if that makes sense, the customer wanted a natural look on the 100mm skirting, no trim.:thumbsup:
E
Eduardo
I think 150 mm is a bit too high ... 100mm looks much better,no trim.
John Benton
1,138
Leeds
Natural tile, natural edge if it was mine. Any sort of trim would take the ruggedness away from the tile. I did the same for a customer of mine, in Dove Grey slate. 100mm skirtings just cut and sealed. Sorry no photos it was from quite a while ago.
Concrete guy
Profiling would look out of place, the natural riven face wouldn't lend itself to a nice neat profile.
I'd probably put a small bevel (2mm or so) on it that would follow the riven surface. It will also reduce chipping from the edge once finished.
An electroplated vanity blade or similar would be ideal for this.
Reply to Riven slate skirtings in the Canada Tile Advice area at TilersForums.com
6K
Hello, can you please help me decide if this is a bad job. We have two balconies and I'm not...
Hello, We’re on the home straight of our new kitchen being fitted, and the fitter has been...
19K
Blunt Tool
Hi all Hoping for some opinions on how to handle an ongoing issue in having with my tiler He...
2 3 4
15K
Anyone ever used Schluter Jolly-MC tile trims? Over the last 3 months, I have been doing some...
6K
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
