Seeking advice on an ongoing job (bevelled metro tiles)
We’re on the home straight of our new kitchen being fitted, and the fitter has been working on the tiles.
I think the clue is in the original post.
No doubt he's decent at fitting kitchens, & knows his way round a few cupboards and stuff.
But plastic trim with them big corners look a bit naff
What's wrong with a bit of chrome round the edges instead?
So, putting the brick bond issues to one side (because that seems relatively straightforward), from what I can tell:
  1. Some people are saying that you can (and should) mitre the tiles to provide the cleanest finish. That would definitely be my preference.
  2. There's no debate that if you use a trim, it should be 8mm (not 9.5mm).
  3. Opinion is mixed on whether you put trim on the top or not.
So at this point I'm not sure how to proceed. I have a feeling that the chap I'm using might not be technically capable of producing the end result I'd like (definitely not if I go the mitring route). On the other hand, I'm concerned that getting this job finished off by someone else would be expensive, given that it's only a small job (and making good on someone else's work, no less).
What would you do in my position?
Grout it and live with it! It's not the end of the world and your asking tilers here who would have done it differently.
why dont you discuss it with him, see if you can come to some agreement . once again i will say its not a terrible job by any standards .
Too much "Plastic" for my liking...Spoils the look...Square edge would have looked better... and I wouldn't have advised trimming top edge..(IMPO).
As others have said...seen a lot worse😵
Hello,
He originally said that he’d mitre the tiles (here’s what we’ve got) to provide a clean finish, which sounded great. However, when he tried to mitre them he couldn’t get a good enough finish on the edge.
His next idea was to use a 9mm trim, and file off and grout the corners (i.e. where separate pieces of trim met). That sounded awful to me, but he said it would look good. In short, it didn’t (and he agreed).
His next idea was to use corner pieces (like this, but plastic) to finish off the corners, which I agreed to. However, he then decided to switch to a 9.5mm trim (without first telling me) because he felt the 9mm trim was too small, and took delivery of and fitted l-shaped corner pieces (rather than the style I agreed to). I've attached the end result.
I’m really unhappy with the finish. I think the trim looks too fat and takes over the tiles, and the corner pieces look really budget. Ideally I would’ve loved to have seen a mitred finish (as we were originally promised), but if not that, a much ‘cleaner’ finish with the trim.
My question is this: can we rescue this? Could the tiles be mitred (and our chap just doesn’t have the knowhow to do the job right), or if not, is there another approach (with or without trim) that would look better than what we’ve got?
I’d appreciate your thoughts!
Fff
Hello,
I almost never mitre ceramics , trim protects the edges and nobody wants to pay for the amount of extra time it takes . just my view ...
Metro tiles are hard to finish and take ages to put up. Its all about asthetics and the clients aspirations at the end of the day.
I dont like the white trim but unless im getting paid more for mitres I wouldnt do
Now I may be old fashioned or just old, but if a jobs worth doing then it should be done correctly.
I would price to mitre because that's the way to do it, so I would either not get the job because I was more expensive or the customer will know to ask the other tilers if they intend to mitre.
Tom Ewer,
Blunt Tool,
Tom Ewer,
Blunt Tool,
