Discuss Rough floor in the British & UK Tiling Forum area at TilersForums.com.
E
Eddie
How'sit hangin lads, I've got to tile this floor
with slate, it's a new floor, quite level but rough surface, should i put self leveling compound on first to smooth the surface, is there i minimum depth i have to put down or can i just fill in the pits, without increasing the hight? Any help would be gratefully received.
thanks Eddie
E
Eddie
cheers gaz cheers dan, i'll try the brick, will post some pics when the job iss done. i can only tile part of the job just now,, because the joiner is fitting a new door, but not for two weeks, so i have to leave a bit around the doorway. should put a Silicon bead around the edge before the skirting goes on or just grout it. Sorry, but also should i seal slate tiles before i lay them or after.
thanks, Edd
Oh, and i forgot to ask should i prime the floor before i put self leveler on, or after or both, or sod it and just put tiles down
thanks again gents Edd
Reply to Rough floor in the British & UK Tiling Forum area at TilersForums.com
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Rough floor
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
