Discuss Rubi DW250N problems in the British & UK Tiling Forum area at TilersForums.com.
RichardB
Yesterday i set my Rubi up to cut some travertine 300x600. When cutting along the 600mm length, just about on the last 150mm cut the blade would wobble and the cut would veer off line resulting in an unnacceptable cut. This happened every time during the day. If i cut the width of the tile i had no problems...only along the length.
I checked everything i could check, wheel in good condition (hasnt done many cuts) Its not warped as it cuts fine the 1st 3 parts of the tile. The bed of the machine was clean and flat. I checked the overhead rail to see if that was twisted, No it was fine. I looked at the bearing wheels that run in the overhead rail and they looked fine.
The only way i could cut a straight line was to mark the tile along its length and watch the wheel as it cut and made any adjustments if i saw it veer off line. Obviously this isnt right !
Then today i got to work and prepared to cut more tiles....Perfect! not one tile cut badly.... What gives here? I made no adjustments and now it cuts fine.
The only thing i can find now is, if you hold the black handle by the motor to pull the wheel through the tile and twist yoour wrist. This will make the whole motor assembly inc the cutting wheel move 10mm either way. What i could do with is finding someone who has the same machine and comparing tolerances.
Any thoughts ??
I have the same cutter and I am suffering the same problem.
Over 300mm width it veres off by 6mm.
Rubi rep has been out as they did not believe me and now its come back from Rubi after being set up and it's still the same.
What did you do to get yours sorted as this is driving me insane.
Richard
Gazzer
Richard
I got rid of the thing and got a Dewalt :thumbsup:
Reply to Rubi DW250N problems in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Sigma or Rubi Tile Cutter? What is you experience with either, or even lucky enough to have both...
Paul Smith
Found a 1200mm tile cutter for around £100 on amazon. Click here to check it out on Amazon...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
For sale this 1yr old Rubi tile cutter with 2 cutting wheels and cleaning kit Overseas move...
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
