rubi star 60 n plus for cutting polished 600x600 porcelain
Here is the new star model from Tradetiler.. ....TradeTiler.Ltd Rubi Star-N Plus Manual Tile Cutters (Top DIY)
Rubi Star-60-N PLUS
Rubi have improved the original star cutters. Mostly buy replacing some plastic component for metal ones
If you are not a full time tiler or are moving into tiling and can't justify the price of the professional ranges then the Rubi Star machines are great.
- Maximum cutting length: 610mm (24")
- Maximum cutting thickness: 12mm (1/2")
- Moving breaking system
- Lateral stop for repetitive and 45° cutting
- Fold out outrigger arms support tile
- Direct view of the cutting and scoring line
- Includes rugged shockproof carry case and 6mm scoring wheel
Price: £69.99 £80.49 Including VAT at 15%
dave thats the one i was thinking of getting from tradetiler.
just not sure if it would have been suitable for 10ml thick polished porcelain.
would the 6ml scoring wheel be ok?
thanks :thumbsup:
dave ive been looking at the rubi ts 60 plus
Rubi TS-60 PLUS
Same as TS 60 but with a newly developed 750kg pressure breaker (standard breaker is 400kg).
Can be more effective for porcelain tiles
Cutting length of 660mm. Also supplied with case and 1 x 6 mm wheel and 1 x 10 mm wheel.
Will cut a 460mm x 460mm tile diagonally
Overall case dimensions (mm) 900 L x 410 W x 130 H
Guaranteed for 5 years
weight 13.5 Kg
Click here for video of TS tile cutter in use
Special Price £158.99 £182.84 Including VAT at 15%
would this one be allot better than the 60 n plus
im thinking of taking up tiling as a career so would this one be better in the long run?
If you are thinking of taking tiling up then get the TX cutter.....much better for large format when you do it for a living..
I have the ts50+ for splash backs and ceramics etc.....then a TR400s for floors with around 300 x 300 hard tiles and then i have the TX700n for big stuff or riven porcelain....
I have 2 other cutters i no longer use...A ts40 and ts60.....
So buy what you will need to be tiler and then you won't waste pennies..
if i had to buy all of them i would be bankrupt before i even start hehee:yikes:
i never thought bying a tile cutter would be such a dilema :mad2:
i think i will go for the 60 n plus, and after i have tiled about 50 m2 of porcelain i will have this conversation again and then i would have made my mind up wether to take tiling up as a career or not lol
rudimm,
rudimm,
rudimm,
rudimm,
