tilinga2z
I wonder if somebody could tell me why there is such a weight difference between the TS 50 L and the TS 60, I can see that there is 6 cm different cut length but the it is 1 third heavier. The TS 50 is only 3 cm shorter but only .2 of a kilo less, in terms of lugging gear around the slightly shorter cut length compared to the almost 4kg weight difference is worth it. Can anybody shed any light on this for me, thanks Rick
TS-40-PLUS 16940 17’’ (43 cm) 12x12’’ (30x30 cm) 1/4-5/8” (6-15 mm) 1,654 Lb (750 kg) • 14.3 Lb (6,5 kg)
TS-50-PLUS 16950 22” (57 cm) 16x16” (40x40 cm) 1/4-5/8” (6-15 mm) 1,654 Lb (750 kg) • 20.5 Lb (9,3 kg)
TS-50-L-PLUS 16950 24” (60 cm.) 17x17” (42x42 cm.) 1/4-5/8” (6-15 mm) 1,654 Lb (750 kg) • 20.9 Lb (9,5 kg)
TS-60-PLUS 16960 26” (66 cm) 18x18” (46x46 cm) 1/4-5/8” (6-15 mm) 1,654 Lb (750 kg) • 29.3 Lb (13,3 kg)
TS-70-PLUS 16970 29” (75 cm) 20x20” (53x53 cm) 1/4-5/8” (6-15 mm) 1,654 Lb (750 kg) • 33.1 Lb (15 kg)
TS-40-PLUS - Maximum Cutting Length: 17’’ (43 cm.). 2 32 8413797169409 16940
TS-50-PLUS - Maximum Cutting Length: 22” (57 cm.). 2 24 8413797169508 16950
TS-50-L-PLUS - Maximum Cutting Length: 24” (60 cm). 2 *18 8413797169553 16955
TS-60-PLUS - Maximum Cutting Length: 26” (66 cm.). 2 *18 8413797169607 16960
TS-70-PLUS - Maximum Cutting Length: 29” (75 cm.). 1 *16 8413797169706 16970
REF
Lateral Stop Chromed and rectified steel guides Single-point breaker
• High Performance Single-point breaker.
• Chromed and rectified steel guides, with anti-corrosion treatment.
• Lateral Stop for straight and 45º Repetitive Cutting.
• Ergonomic Shape and Reinforced Base.
• Special Mounting for the Breaking System Lever.
• Supplied with case and complete set of tools (Ø 1/4” (6 mm.) and 13/32” (10 mm.).
• Direct vision of the scoring and cutting line.
• Ø 1/4” (6 mm.) to 7/8” (22 mm.) adaptable and interchangeable scoring wheels.
• Adaptable accessories: Adjustable Square (Ref. 18820 / 21 / 22)
Manual drill (Ref. 15925 / 27).
STANDARD
www.rubi.com
TS PLUS Professional Tile Cutters
TS PLUS PROFESSIONAL TILE CUTTERS REF
ACCESSORIES
REF
STANDARD
www.rubi.com
ACCESSORIES
